Help diagnosing p0420
For the last few weeks I've been getting p0420 codes.
I've replaced the pre-cat o2 sensor - so I don't think I'm looking at a bad sensor.
I have a registered version of vagcom - are there any measurement blocks that I can log that might help me diagnose this problem?
Could a leaky turbo or leaky oil lines cause such a problem?
I'm wondering if I should take the car someplace to have the exhaust 'sniffed' (a state inspection facility).
Any help or advise would be appreciated.
Thanks!
Thanks!
No tune?? I guess you mean something other than a tune up (plugs, gapping, wires, etc).
OK - so where is the post-cat sensor? Down below in some hard to reach place? (Even that top one was kind of hard to apply torque to).
no i mean tune, like giac apr uni.... they can right out the code for something like that
and the second sensor you will probably need to get from under the car... just follow the wire back to the other side of the car....
[QUOTE=turbo kraut;1198336]no i mean tune, like giac apr uni.... they can right out the code for something like that
QUOTE]
Hmmm - sounds like another reason to chip - as long as the car passes the inevitable sniff test. (Only 2 county's in PA require an emissions inspection and I live in one of them).
QUOTE]
Really? Salesman/mechanic (not my regular mechanic) said something different. He said bank 1 was top one (pre-cat) and bank 2 was the other one (presumably post-cat). I guess either of us could have been wrong or misunderstanding something.
thanks. That all seems reasonable and helpful.
So - time to pay for a sniff test. If I pass it, then I don't worry about the codes and maybe think about a tune.
It seems the upsides to a tune are fun! and it might get rid of error codes. downsides are cost/labor to upgrade, more expensive fuel required, and more ongoing maint.
Am I missing anything?
