HELP! THIS CHICK Need Audi back up and running been sitting for a year.
Old 01-19-2012 | 03:16 AM
kdcrowe911's Avatar
Default HELP! THIS CHICK Need Audi back up and running been sitting for a year.
So I have an 1998 Audi A4 Quattro LOVE MY CAR. Purchased it when my Dad passed away. It has 120k on it have had it since September of 2009 in May of 2011 while driving all of a sudden it started to lag. I am very gentle with this car. I am a female. I need my car back up and running I have numerous Doctors apts, Oncology apts and having just the Yukon is not cutting it for my family.. Replaced the CAT, Coils, etc etc did it all. Even new timing belt. Well you go to start her up and she starts like a champ but the Cat is glowing red and smell of gas! It seems as if to much gas is getting dumped in somewhere. If that even makes sense! What could be going on? I have read about taking the ECU out etc etc could this be whats going on throttle body needs to be reprogrammed? HELP!
Old 01-19-2012 | 08:53 AM
chocalotstarfish's Avatar
Super Moderator
I would start with pulling codes. You can do this yourself or at an autozone/advanced auto. Those codes can point you in the right direction. Also what motor do you have? 1.8t or a 2.8?
Old 01-19-2012 | 01:05 PM
kdcrowe911's Avatar
1.8 Quattro Turbo tiptronic and this is what is happening. Someone responded to another post and asked if I changed all coil packs which was done.. It idles fine as soon as u play with the throttle you can watch the cat turn orange and its brand new and by time u drive it for 5 mins everything is orange and hot and you can smell raw fuel coming out of the tail pipe. any ideas?
Old 01-19-2012 | 01:38 PM
turbo kraut's Avatar
Tech Guru
O2 sensors. But as don said are there any codes? If so what
Old 01-30-2012 | 11:49 PM
dbcooper024's Avatar
Default last stone turned over..
It was the ignition control module..
Old 01-31-2012 | 09:34 AM
M5S5's Avatar
Tech Certified
You should really do a fuel psi test , check fuel psi regulator for a fuel leaking into intake system , stuck open purge control valve , mass air flow sensor , coolant temp sensor.
The exhaust should not be getting that hot under normal driving unless there is a serious fuel mixture problem.
Also codes & data would be a must for proper diagnoses.
StephStephRevolution
12-24-2012 09:58 PM
kdcrowe911
01-30-2012 11:46 PM
DRWonoski
01-07-2012 12:58 AM
johnebusch
10-29-2005 02:56 AM
Fieldy
08-05-2005 03:30 AM
Quick Reply: HELP! THIS CHICK Need Audi back up and running been sitting for a year.
