help, check engine light on after bov installed.
you can use a BOV without problems if its adjusted correctly and closed at idle. most people have a hard time figuring out how to do this, which is why a DV is a better choice. there is no performance gain using a BOV vs a DV on the stock turbo. unless you have a real reason to use one, stick with a DV so i dont have to keep reading these threads.
I have the exact same valve as you, the forge splitter, you can only make it full dv, full bov, and hybrid 50 50.
you can adjust how stiff the valve spring is by turning the top, here for more details http://www.forgemotorsport.com/conte...duct=FMDVSPLTR
has anyone tried our maf inline, after the bov/dv?
I think the lesson here for all (and we'll all have to say it all again very soon) is that having a BOV just for the "cool sound" is pretty ricey. Honestly, if it is such a hassle, possibly damaging, and the car was designed with a DV, just stick with a damn DV!
I don't mean to be rude but, why you talk about dv, bov sound and bla bla bla. I am trying to get an alternative to make bov works fine not to argue dv is best or the damage to a car.
#18
i have audi a4 b5 1998 1.8t automatic. i change the stock dv to the forge splitter and i set 100%bov. for the first week it runs good and no problem. but on traffic stop and go, sometime my rpm drop very low and causing engine stall. the check engine light also showing. is there anyway to fix this?
inkhaton
08-16-2012 03:37 PM
parlayin
02-10-2010 12:33 PM
MrTigz5254
03-07-2008 11:56 PM
