Help- Can't drill out a stud in the cylinder head.
I have one exhaust manifold-to-cylinder head stud that is causing me a lot of pain... drilled a hole, tried a screw extractor... extractor tip broke off... re-drilled, but the new hole was slightly off center, cut just a little into the threads. At this point my mind is exhausted. Any suggestions? My last idea is to just leave it like that and seal it with sealant or JB weld. Any chance that'll hold (the other 5 studs are fine)? This car is killing me... slowly.
That's probably the sensible thing to do. And then just bolt it down with something from homedepot? Should I add a washer? I'm kind of scared the bolt won't take the heat and cold, though. Especially during the winter. Think it'll be okay?
I'll probably have to do the same to the exhaust manifold-to-downpipe studs. It's just the temperature fluctuations i'm worried about.
Before you try making it larger you might want to make sure the bolt size is going to fit thru the manifold hole. Also use a bolt that is of the same material as the ones already being used.
As for the head itself, it is Aluminum Alloy. The block is Iron.
quick way to tell is use a magnet if it sticks it's steel of some sort, if it doesn't it's aluminum. there are other metals that are magnetic and not magnetic but steel and aluminum are the most widely used in the automotive industry for bolts/studs/fasteners.
Is the block out of the car? if so you could try heating up the area around the stud, not glowing but just hot. also try some penetrating oil
AudiTurbo
01-07-2014 08:03 AM
