Heat issue...yeah I did my research
RE: Heat issue...yeah I did my research
theres no bleed valve but lifting it up puts the exit hose on the tank at the very bottom making the air go to the top, essentialy bleeding the air off. however if your coolant is at the proper level this should happen on its own because the exit to the tank is at the bottom normaly. sometimes squeezing the hoses by hand will agitate the liquid enough to bleed the lines if thats the problem
