Heat issue...yeah I did my research
Old 07-26-2008, 01:13 PM
Silver Bullitt's Avatar
Default Heat issue...yeah I did my research
So I could not find a definitive diagnosis on in the forums.
My heat works foir a few seconds then gets cold....so probably not the heat gate, right?
Both heater core lines (supply and return) seem pretty damned hot.....so probably not clogged right?
What would the issue be? Air? If so what is the easiest /best way to bleed it?
Thanks all!
Old 07-26-2008, 01:30 PM
Jc61990's Avatar
Default RE: Heat issue...yeah I did my research
where do you live that you need the heat?
Old 07-26-2008, 02:36 PM
Seattle. Better to fix it when it is 60-70 out than 40 and raining.
Old 07-26-2008, 05:12 PM
Audi_Skydiver's Avatar
HAHA thats true... Does it ever get hot again if you leave it on for a while? Also what happens when you put the cold on? Just wondering.
Josh
Old 07-27-2008, 12:30 AM
Tweaked's Avatar
Hows the engine coolant temp when running?
Old 07-27-2008, 08:14 AM
CRAZYHAWK's Avatar
Remove the three screws from the G-12 reservoir, and lift it
with heat on high. This should bleed the system.
Old 07-29-2008, 11:35 AM
Ok I will try to reply for the 15th time (hope they fix the forum soon)
Old 07-29-2008, 11:36 AM
Temp is top dead center
It will heat up again after it has been off for a few minutes.
Old 07-29-2008, 11:37 AM
I took the resevoir off last weekend but it seemed like it would only lift a few inches. How HIgh should it go and are there any tricks to this?
Quick Reply: Heat issue...yeah I did my research
