headliner
ok this is pretty easy to do but gonna seem overwhelimng to do a lot of parts to remove. remove the a-pillars. bpillars. cpillars and rear trim at rear window. just pulls down. remove rear light switch from headliner, remove front lights and sunroof panel. should have two trim pieces that come off then two screws and fall right down. to removed the healiner there will be a screw where the front panel was removed very small screw. and in the rear it just snaps into place and if you have sunroof you have to unclip the ring around the sunroof area its easy just slide sunroof open and you will see a black ring that goes around sunroof and into the headliner just clip it off and the headliner should fall down. lay down the two back seats and slide it out through the trunk so you dont crease it.
after you get the "oh ****" handles off, the headliner is only held onto the roof around the sunroof by clips. They just snap off. You'll have to tug on the headliner down and you'll feel the headliner snap down. There's about 8 clips holding the headliner around the sunroof. No way to get to the clips except for a firm tug down on the headliner.
