Headgasket R&R 2.8 12v advise?
#31
Get new bolts and put them in. Everything I've ever seen/done/read says that it's ok to change them and keep the gaskets you already have in there. Long as you don't heat cycle them by starting the engine you can change those bolts, retorque the heads again and continue with your rebuild.
#32
+1 for Chris!!
I droped an EGR bolt down #6 cyl. through the spark plug hole.... i kept telling myself to put the dam plugs in... but no. I can not even begin to explain how angry i am at everything... now im on the search for a magnet. and i feel pretty soon.. some fuses for my brain, as i am now on overload dot dot dot dot dot.
#35
#36
^^click the pic if you wana see a bolt come out the cyl! haha
ok. so washed down the front clip, now im bolting the thing on... dam all these bolts!! which one to choose? theres a couple different sizes but ill see how things go
#38
i need to get a new vc gasket,, somehow my new one has a cut in it..
and i had to find a bolt/washer for the right side as the prev owner lost it.
AnD Wah BAM,, front clip on
ok so i cant find the other end for the connector all the way to the left (in this pic). does anyone know what this goes too? i looked but no loose wires
#40
[/QUOTE]
headlights maybe? just speculating
other than that it looks like your adventure is meeting with much more success than mine!
[/QUOTE]
