gt2x elim
RE: gt2x elim
If the PC-16 is the 380cc file, then yes. That is unless there is another 380cc file available. You will have to limit the boost to 22psi so you dont over spin the turbo. You can do that with a mbc/ebc if you bypass the n75. YOu may even be able to get it tuned for less boost.
If done right, Mya4T should see around 250whp with his AEB car and plans for w/m. For awd, 230awhp would be doable on boost alone. The point of using this turbo is stock like spool with a large amount of low end tq all while still holding power where the ko4-15 cant.
RE: gt2x elim
You could always try to run the 440cc file with the elim or trade it for another ecu. Im not sure whats all availble from them. You should contact the local dealer to see what they can do for you first. Not sure wheres the cheapest place to get the elim, you can try boostfactory, kineticmotorsports, renn-art, or just strait from atp
RE: gt2x elim
ORIGINAL: cincyTT
#19
RE: gt2x elim
depends on if you install it all yourself or not and what you already have on your car...
- elim = around $1000-$1200
-fmic = $400-$1000
-tune = $400-$500
-all little necessites = around $100?
-instalation = ? (a lot)
there is more that you will probably need, but im too tired now
im not sure if these #'s are correct, but around there im guessing
-fmic = $400-$1000
-tune = $400-$500
