Got her all buttoned up!
And then I find she's leaking coolant.
The lower radiator hose (from radiator, to thermostat housing and up to coolant res.) wont stop dripping. I disconnected and cleaned (and got a facefull of coolant) multiple times, I'm just stuck.
So my question is this: The upper hose is of a similar design: The hose ends are hard plastic and you have to really work hard to get it on. Once on, the hose locks into place with a metal clip. The inner design of the plastic creates a seal. There's still a small notch with a screw clamp in it up top.
The bottom hose was a breeze to put on. It just slides right on. Then there's also no clamp, nor a place for one. Besides, I put one on and it did not stop the "bleeding". I'm thinking I somehow have the hose on wrong, the spring clip is bad or the new radiator I bought from BHER has a smaller opening at the bottom and is leaking.
Any insight oh-so highly revered Audi gurus?
(The project was supposed to be finished today. It was nice and sunny and the roads begged to be driven. Plus I really wanted to play with my new snub mount and SPLIT-R valve.)
considering red RTV is used by most people to seal up their water pump gasket, i think it'd be safe to use. put the stuff where two ends meet. i wouldn't use excessively though as it'll probably clog up something if you have a whole crap load in the system lol.
