Going BT soon
Old 06-16-2012, 09:03 AM
ThatRetardedKid's Avatar
I noticed some small screw holes in the top of IC. Don't know how deep they are. Could it be leaking from there by the way I'm in Atlanta
Old 06-17-2012, 10:33 AM
CCA4's Avatar
Those bungs should be welded to the core, I'd be surprised if they're leaking but its possible. If you want to test it, take the core off the car and use an air compressor to pressurize it to 10 or 15 psi and listen for leaks
Old 06-17-2012, 02:09 PM
ImTheDevil's Avatar
Design and quality of the IC will also determine a lot. If it's a $75 eBay tube/fun design, don't expect much. Bar and plate cores are more efficient but more costly. And as stated above, if you have a big core, the turbo is probably straining to fill it.
Old 06-19-2012, 08:39 AM
Oh ok. CCA you said you know how to create a tester? Also what about the turbo seals can I have a mechanic replace them? I have a oldschool hks bov I'd like to throw on will it work?
Old 06-19-2012, 09:11 AM
CCA4's Avatar
This is a good DIY for a boost leak tester:
VWVortex.com - DIY: Boost Leak Tester
I'm confused about turbo seals and a blow off valve, what does that have to do with your boost leak?
Old 06-19-2012, 02:38 PM
I mean nothing, I'm for in the future references because I eventually want to put on the 71r. so I'm trying to get a list of all what I would need to have the setup. Btw thanks for the link.
Old 06-19-2012, 03:15 PM
CCA4's Avatar
ohhhhhh gotcha. Sorry, I was confused.
A BOV will work if you're running a MAF-less tune, otherwise you'll run rich in between shifts and probably throw a CEL.
Usually to have a turbo rebuilt you'd have to send it back to the company who made it in the first place, or DIY. Your average auto shop wouldn't touch that job.
