Going BT soon
Old 06-14-2012, 01:33 PM
ThatRetardedKid's Avatar
Default Going BT soon
So I picked up my 2871r today from an old friend that upgraded. He told me the seals needed to be replace, so im asking is it possible to do because the shaft and bearings are in great shape no play whatsoever. Also im putting on my fmic tomorrow on my k03 until the turbo gets a rebuild. I wanted to know if I could use the stock dv and would i have to use that sensor off the stock smic?
Old 06-14-2012, 01:37 PM
CCA4's Avatar
The stock DV will work until you increase the boost. What year is your car? I assume you're talking about the MAP sensor? There should be a bung for that on the plumbing for the FMIC. If there isn't, you'll need to add one.
Old 06-14-2012, 01:41 PM
I have an 99 aeb
Old 06-14-2012, 01:44 PM
CCA4's Avatar
That car shouldn't have a sensor on the side mount.
Old 06-14-2012, 01:48 PM
Ok your the man cca my friend just a did fmic off on his 2001 and that's why I was asking I guessed it's different with an aeb
Old 06-14-2012, 02:01 PM
CCA4's Avatar
Yep, 2001 will have a MAP sensor on the SMIC, your car does not. If there's a hole in the FMIC plumbing for that sensor you can just plug it with something or cut that section of pipe out and replace it with a silicone coupler.
Your DV will be fine up to about 12psi. After that you're gonna want to upgrade to a 710n from the 225TT or a rebuildable metal piston-style DV like an APR R1 or a Forge 007/008
Lemme know if you have any other questions!!
Old 06-15-2012, 08:09 AM
so I got my front mount on but I went from 15 pounds of boost to 10. Any reason why it would I have a giac chip
Old 06-15-2012, 08:33 AM
TaConklin's Avatar
A small bit of boost drop is expected with going to a front mount, but usually less than 1lb. Check all the connections and couplers.
Old 06-15-2012, 08:37 AM
CCA4's Avatar
Boost pressure will usually go down with a front mount because of the added volume of the core, but never by 5psi. Sounds like you've got a boost leak my friend! Where are you located? I have a boost leak tester if you'd like it, or you can just build your own.
Old 06-16-2012, 12:11 AM
meloman's Avatar
If you put on a front mount meant for a much larger turbo then you are going to see a decrease in performance when it's used with the stock k03, the turbo may be having a hard time filling the core.
