GIAC chip problem, please help
it was actually a chipped ECU I got off ebay from someone who posted it here. Here is the item URL if you wanna check it out: http://cgi.ebay.com/ebaymotors/ws/eB...m=120286615006
It may be that the stock DV spring is opening under boost. This would make a pathway for lost boost back into the intake and cause you to run rich and probably get a misfire. Just a theory. I'd say def pick up a 710N dv and try the chipped ecu again. The correct fault code will help in the meantime.
Another theory is, there have been at least a couple bad "chipped" ECU's circulating on ebay/classifieds throughout the past couple years.
ok so I'm checkin out some DV's, and is the one off neuspeed a good one? I see it says its the same as sold at a dealer, which I may end up doing anyway, but the one off neuspeed is nearly thirty dollars cheaper. I believe it is as said before a Bosche 710N
audiondubs25
06-01-2008 03:14 PM
