gear ratio question. .
so ill get to the point quick, is it just me or does the audi a4 1.8t have some short *** 1st and 2nd gear?
when i try to floor it i hit redline (6300rpm)like stupid fast then i gotta jump to 2nd and that 2 goes by stupid fast until 3rd it holds it a little long. i have that pc16+injectors file i know it makes ok torque but dam i cant even hold 1st gear for 2 sec bc am already passing redline same with second gear.
is this normal? or is there something else am missing here?
also i was thinking of working on the head and internals you know springs so i can rev higher, rods, crank etc i am going big turbo so i was thinking this might be a better idea . what do you think? or should i go look for the tranny?
o really? so then i should just high rev build the head and take it from there then? seems like the better option. it the statement about the 2 tranny's been close to the same thing then there is no reason to change it.
well i am planing on doing it all in one blow head build(springs,retainers,exhaust valves) and rods all at the same time i might even get forge crank while am in there why not but thats a maybe i still think the stock crank can handle good was looking into maybe a better intake manifold i seen some good looking ones and i think the BT set up well benefit better from it than a small turbo. am still making the list, right now i just order exhaust/catback and the test pipe came up to $450 total for that i need the exhaust anyways and the test pipe so that was a must get now.
