gas mpgs
gas mpgs
hello, i have a 2001 a4 2.8 quattro, i was just wondering what kinda gas milage you guys get. it seems like i am getting 15-18mpg i drive about 1/2 and 1/2 highway, and city. does that seem rite? is there anything i can do to increase my mpg? thank you
RE: gas mpgs
Seafoaming also helps some, but prepared to change your oil and your spark plugs while you're seafoaming it. It's safe to pour it in the crankcase, just let it run idle for about ~20-25 minutes, then do a quick, easy lap around the block, come back, let it idle for 5 minutes, then do the intake as per:
http://audizine.com/forum/showthread.php?t=125055
RE: gas mpgs
firstly theirs a search button and this is probably the 2nd or 3rd thread ive seen on MPGs but seems a bit low, stricly city driving i see about 21 average and highway i jump up to almost 35. and this is on teh old 12v motor with 160k. try the seafoam thing and replace vac lines.
RE: gas mpgs
I'm getting 22 mpg in my 2.8 Avant with about a 50/50 city/highway mix, so you should be getting around that. Definitely do a search, there're plenty of useful tips on increasing economy in the other related threads. If they're old, you should replace your spark plugs (after seafoaming).
RE: gas mpgs
ok great, thanks for the quick reply...my mechanic or local autozone wouldnt do this sea foam for me right? it seems easy but i would rather not do this myself. if they wont do it, is there something else that has the same effect, that they can do? thanks again
RE: gas mpgs
Then just pour a can of Seafoam into your gas tank and half a can into your crankcase (where the oil goes) about 30 miles before your next oil change. Have your mechanic change your spark plugs and check the air filter.
RE: gas mpgs
ORIGINAL: SAudi
