gas guage
Old 10-05-2009, 08:17 PM
Andrew149's Avatar
Default gas guage
okay so i went to fayettville i had a 3/4 so i took a break after 2 hours of driving came back started it up and it was 1/4 a tank so i filled it up but why does the car gas guage doesnt work right is there a fix what fix is it how much blaw blaw blaw anyone else with the same issue?
Old 10-05-2009, 08:30 PM
ImTheDevil's Avatar
Check the tech area of audiworld.com or www.audidiy.com - one of them has a writeup for fixing a broken wire on the sending unit and cleaning its contacts. 95% of the time a screwy gas gauge is fixed this way.
When it tells you to solder the wire, you can use splice connectors to put a jumper in to repair it - I did that and haven't had a problem since.
Old 10-05-2009, 08:32 PM
Andrew149's Avatar
oh really dude that is great news im going to do it!!!!!
Old 10-05-2009, 08:37 PM
Andrew149's Avatar
http://www.audidiy.com/b5a4.php im not seeing it buddy
Old 10-05-2009, 08:39 PM
ImTheDevil's Avatar
I'll try and remember where the F it was and will link you to it.
Old 10-05-2009, 08:42 PM
Andrew149's Avatar
awasome man im excited it really bothers me its a big deal when u drove off with 3/4 than have nothing
Old 10-05-2009, 08:45 PM
ImTheDevil's Avatar
Found it right under my nose lol - it was in the AF DIY section:
https://www.audiforums.com/forum/diy-do-yourself-55/fixing-erratic-fuel-gauge-jestnomen-3621/
Old 10-05-2009, 08:47 PM
Andrew149's Avatar
yepp i figured i haft to replace the sending unit is that what you did or did u just clean it out?
Old 10-05-2009, 08:50 PM
ImTheDevil's Avatar
Don't replace it. Pull it out and clean the terminals. Look for the thin wire that runs under the arm on the sender - it's obvious when you look. Most of us who had the problem have found that wire to be frayed or broken. Repair it and you should be in good shape.
Old 10-05-2009, 08:51 PM
Andrew149's Avatar
awasome **** dude i will do that im good with electronic's so no issue there now i need to get to that half tank
Quick Reply: gas guage
