Fuse box
Fuse box
I have a T reg 1.9TDI estate. I did not get a manual with the car and just can't find the fuse box. The heater fan isn't working properly and I just wanted to check the fuse. Where on earth are they? Honestly, I'm not normally this thick.
Fuses are behind a door on the end of the dashboard. Open the door and you'll see a plastic panel on the end of the dash. Carefully pry that up and a fuse chart is on the back of that plastic panel. On a US spec car, it's on the driver's side.
