Fuel pump upgrade 1.8T AEB
answered
best pratical pump upgrade for you is the walbro. i run the gss340 that i got from pagparts. it came with an install kit, but it was ****. the foam didnt fit the basket, didnt come with a sock. i wasnt happy with the kit. if you want the cleanest solution, i believe the only way to go is the atp aluminum adapter which fits in where the stock basket does. obvioudly more expensive, but better than the rings around my fuel pump im running. o yeah, since my pump didnt come with a sock, i ran down to oreillys and told them to find me one that fit. i jammed some chevy sock on my pump and im pretty sure its still on there. and just for a note, i cant hear hear my pump run at all
I actually ran a Walbro GSS340 in my stock basket with no sleeve and had no issues with it.
This company offers different thickness sleeves and sock filters that can be bought alone
This filter works for the GSS340
What filter sock to use in conjunction with a Walbro 255 to make it a 'plug and play' install?
Is there some substantiation for the 300 awhp (400 cHP in my books) available?
I have a fuel pressure gauge installed, and are not (yet) seeing a drop.
Running 22-24 psi on 350cc/4 bar, but pegging the 70mm (ID) MAF on my AEB from 5k rpm on. Area/flow corrected, that equates to 256 g/sec (320 cHP in my books).
Hope eliminate the current MAF bottleneck by installing a 76mm ID MAF housing (and corresponding fueling) this weekend.
If above claim holds water, I may still get by with the stock pump (not expecting to make more than 350 cHP even de-bottlenecked).
ECS Tuning
05-11-2015 04:19 PM
