Fuel leaking under FPR
Hi all,
I just finished replacing my pcv valve, turned the car on and noticed fuel dripping out pretty heavily from the end of the fuel rail, underneath the FPR.
I'm afraid to turn the car on to diagnose it, does anyone have any idea what this might be?
I have smelled gas for a few months.. but it seems like the car would have blown up by now if this much gas has been leaking out.
The fuel lines seem intact, and fuel pressure is steady at 62psi (it has been at this pressure for over a year, even though I have a 5bar FPR installed for my k04)
How safe would it be to drive it to a shop to have it diagnosed? How difficult is it to install a new fuel rail?
Thanks so much.
Thanks so much.
5bar is 72.5psi. The 62psi you're seeing I'm assuming is at idle, with the vacuum line attached to the FPR. Normal vacuum is 20inHg, which is about 9.8psi. So 62+9.8=71.8psi which is pretty darn close to 5bar. To verify: remove the vacuum line from the FPR (keep it pinched) and then look at your fuel pressure gauge.
There's an O-ring at the bottom of the FPR which might be in need of replacement.
what i would do is have a buddy turn the ignition on so the fuel pump primes and watch for the source of the leak. it really could be leaking anyone and just riding the rail all the way down to the bottom of the fpr. id check all the injector o rings and of course the fpr. on a side note, i developed two massive fuel leaks, one from a torn o ring and one from the fuel line breaking. i got very paranoid and now have a fire extinguisher in my car
It looks like the 4th injector has some fuel around it, but the FPR itself has fuel on it, too. I checked the O-ring under the FPR, and it looks fine.
If it's the injector, I don't really see how the FPR could have fuel on it, because it's up higher than anything else on the fuel rail. Maybe if the injector is blocked, the FPR could leak??
I'm worried that I may have leaned on the fuel rail while doing other work. Is it possible that I may have broken an injector or something? I'm not a heavy guy, and it looks pretty solid..
Does anybody know how I would check the area of the 4th injector to find the problem?
Thanks very much, can't say how much I appreciate you guys for helping.
They often leave the option for aftermarket (non-stock-fitment) AFPRs with aftermarket rails. But sometimes they give the option for installation of a stock-fitement FPR:
Adapter - 1.8T Fuel Rail - Stock FPR - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
For this rail:
Fuel Rail, 1.8T, Billet Aluminum
For this rail:
thanks, metalman.
I removed the fuel rail, injectors, and fpr today to inspect them and I can't figure out where the leak is coming from. The O-rings on all seem fine. If an injector was not spraying or was clogged, would there be a major fuel leak?
I don't really know what to look for on the injectors, I just know they look normal. What else can I check?
