Front strut - pinch bolt won't budge
Old 07-03-2011 | 06:18 AM
gdog87's Avatar
although as its the strut you're replacing... maybe you can get enough clearance by following Broderick's suggestion to disconnect the control arms inboard side.
its going to be an **** during the rebuld getting the recommended 47mm clearance with the arms connected to the hub carrier though
Old 07-03-2011 | 09:19 AM
ImTheDevil's Avatar
That's exactly what you do - take out the three bolts through the top of the strut mount in the engine bay, lean the assembly out, and put a 16mm wrench on the inner control arm bolt head and the nut. Remove the bolts, swing the CAs around and remove the strut.
Pinch bolt removal - if you go this route, back the nut off some, pry the pinches open, set that sumbitch on fire with a map gas torch, and wail the hell out of it with a 4pm sledgehammer. Tried and true. Fire and violence win over pinch bolts.
Old 07-03-2011 | 09:42 AM
vtraudt's Avatar
I stayed away from fire, afraid to ruin the ball joints (rubber).
Old 07-03-2011 | 12:30 PM
ImTheDevil's Avatar
Good plan, I wasn't thinking about it in terms of what you're working on. Leave that bolt alone, dismount the upper control arms at the other end as described above, and you'll save yourself a lot of hassle.
Old 07-03-2011 | 12:45 PM
DOC_DEPALMA's Avatar
Smells like victory
Old 07-04-2011 | 01:03 AM
rawdney88's Avatar
if you are careful, you won't ruin the bushings with fire.
Old 07-04-2011 | 01:57 AM
airguard350's Avatar
Tech Guru
I lucked out with mine and was able to tap it out with a punch but I still had to cut the ends off. I replaced it with a grade 8 bolt from Lowe's.
hartsoe1
12-07-2012 12:22 PM
vgo
08-01-2012 11:04 PM
Nevalite
08-28-2011 03:52 AM
raudi28
08-24-2011 05:11 PM
legendpilot
03-12-2009 09:57 AM
