Front pump removal
Front pump removal
Front pump removal calls for 2 hours on all data on a 5hp19. It is a perfect transmission and I have a parts tranny that has a busted rear case with a good pump. Need to know what I need to do to swap front pumps, do I need to take the diff off or something?
Thanks
Tom
Thanks
Tom
Get some pix.
yes you have to take the differential out, oil pan after draining of course, and the valve body, then you have to take 5 pieces of rubber ($7.00 a each if you damage them)
look at your original post
https://www.audiforums.com/forum/sho...ighlight=5hp19
I updated with more info for you
HardRock1
07-01-2010 10:20 PM
