front door wont open from inside
Old 05-30-2012 | 02:09 PM
Stephenwhite990's Avatar
Unhappy front door wont open from inside
The front drivers door wont open from the inside , works perfectly from the outside , stripped the door lock out of the door and everything seems to work fine ,I then put the door lock back in the door and it opened fine untill I locked then unlocked the door , now it wont open again from inside .It is as if the interior handle isnt moving the lock release enough , maybe the lock is worn , but everything moves on the lock freely , any help greatly appreciated
Old 05-30-2012 | 07:00 PM
Christopher Nemitz's Avatar
the cable that goes from the lock assembly to the inside handle needs to be cliped into a certain spot on the door panel I believe, it could be popping off.
Old 05-31-2012 | 07:29 AM
no its not popped off , even with the door card removed ,I can see the lock moving when I pull the wire , I think either the wire has stretched ( unlikely) or there is something worn on the lock itself
Old 05-31-2012 | 08:28 AM
jonbonesjones's Avatar
Moderator
pop th cable out of the door handle on the inside handle. DOnt lose the little metal clasp, it will fly, then pull the cable all the way out. If nothing then your right to suspect its worn, or broken. cheap fix from a yard or a part out.
Old 09-09-2018 | 08:44 AM
John_E's Avatar
Make sure the cable housing is clipped securely in place. It is not enough that the cable end be attached, because opening the latch depends on relative motion of the two. If the housing moves when you pull the cable, the latch will not open. (Been there ... done that on my 1996 A4.)
fromzerophreak
11-07-2009 02:12 PM
bornnation29
06-27-2009 05:18 PM
540guy
02-05-2009 08:22 AM
viviorunitia88
05-26-2008 05:47 PM
operator
01-14-2008 11:55 AM
Quick Reply: front door wont open from inside
