Forge DVR Installed, Questions..
OK So after a long and "harder than it should have been" process, I have the Forge DVR on. My hands are cut up but I got it on. I started it up and reved it a few time, and I dont have a CEL or anything, the throttle just seems to respond a lot quicker, is that normal? I mean thats cool if it is, maybe my stock DV was not that great, but I'm just worried i did it wrong. It is a Diaphrgm valve and I installed it the same as the stock like cincyTT said to do, I dont know. I am just a worrying nerd I guess. When anyone else did a forge DV on a otherwise stock car notice this difference? I know its a total noob question, I just dont want something that I voluntarily did to **** me over. Thanks
RE: Forge DVR Installed, Questions..
I don't think a dv will help with throtle response but if it did that can't hurt. If your not chipped you probably won't see any difference except there might be more woosh noise when you let off the gas. If you are chipped the car should drive smoothly. The instal is easy and CincyTT surely gave you good info so it sounds like you don't have anything to worry about.
