Forge DV Splitter Valve
Hey guys!
So I'm running a Forge DV Splitter Valve in the hybrid position. And I keep burning my MAF sensor (probably went through 2 or 3 already) And we all know those little ******* aren't cheap. Am I burning out my MAF sensor by using the hybrid position or should I just go fully recirculating?
Forge claims that your car should be safe in the hybrid mode if you install it correct. (I'm almost positive installed it right. Even triple checked that it was right)
it's just the stock air box right now with a K&N drop in air filter. That's what I first thought when it threw the CEL code for the MAF sensor the first time. But it's doing the same thing as last time. Fluttering idle when starting for the first time. Can't run A/C or Heater without the car jumping.
