Flashing Break Light
So I just finish replacing the right rear bearing and bushings. Got everything put back together and on first start-up before test drive I notice the ABS light is on. Also the Break light(dash light) is blinking but if I lift the E-break handle it stops flashing and stays on. Any ideas?
Thanks
Thanks
That's what I always do. I ask because it sure seems to me that something happened with that ABS sensor. Those are the symptoms you'd get if you left a sensor unplugged. Those are also the symptoms you get if the ABS module goes bad, but that would have nothing to do with your wheel bearing job.
james0013
10-21-2008 11:24 AM
james0013
10-21-2008 08:38 AM
