Firewall suggestions
im trying to figure out where is the best place to feed some lines/wires through the firewall.. id like to install my VDO boost gauge on the steering column pod.. does anyone got any pics of where to go about the firewall or how to do it?? ive been disconnecting the battery and ECU box just to see if i can get through there, but its been a lil frustrating..
any ideas or suggestions?????
you need to get a vacuum source into the cabin? you can thread the vac line thru one of the rubber openings on the front of the ECU box, then open up the box and remove the ECU and there is a clear path right down to the back of the dash board. you dont have to remove the ECU but it makes it easier to see the hole.
thanks for the pics!! i really appreciate it.. now is the rubber cap u suggested behind the ECU box?? its difficult to get a hand behind the ECU box.. i see where u made your vac line connection.. nice! where did u tap for the power?
I tapped the power from the stereo illumination (mine doesnt need pwr to operate) so when i turned my lights on the light would come on on the gauge too. The hole is not behind the ecu box but just below the left corner as you can see the amp cable and vac line going in that direction.
also, did u run the vac line behind the engine or around the front like stock? is that a t-fitting u connected to it? im wondering if i have enough vacuum hose to do all of this.. or if i need more length or other fittings to work with..
did you re-route the vac line to the rear of the engine or to the front? & is it the same vac line that goes down to the DV? or is there another vac line im missing??
