Finding and replacing Bank 1 Oxygen Sensor 1?
Old 07-18-2013 | 10:23 PM
lespaul2510's Avatar
Default Finding and replacing Bank 1 Oxygen Sensor 1?
Hi,
My CEL went off recently and the scanner said the bank 1 O2 sensor 1 is no good (code P0130). Are there any DIY's out there on replacing these stupid things? I long for the days when cars didn't have any of this emissions nonsense and they were easy to work on. Supposedly the O2 sensors are easy though...hopefully.
Old 07-19-2013 | 02:05 AM
Expplucky's Avatar
is it post cat or pre cat? all you gotta do is follow your exhaust up it should be on the down pipe right before the flex pipe and make sure u get a can of pb blast and let the o2 soak over night before you try and get it off.
Old 07-19-2013 | 12:34 PM
CCA4's Avatar
From your sig pic, it looks like we're talking about a 2.8 here. Bank 1 is passenger's side, sensor 1 is pre-cat. If you jack the car up, find the passenger's side catalytic converter, and work your way forward towards the engine, you should see it. Here's a DIY guide to replacing the precat sensors:
2.8 Precat O2 Sensor Replacement DIY
Old 07-19-2013 | 11:19 PM
Kamil`'s Avatar
Sensor 1 is actually right after the exhaust manifold. Sensor 2 is after the flex pipe, behind the cat.
Trust me. Already changed mine.
Old 07-22-2013 | 10:45 AM
CCA4's Avatar
Right: 1 is before the cat, 2 is after it.
Old 07-06-2019 | 03:48 PM
Kradvk's Avatar
Default Upstream or downstream
If it’s sensor 1 bank 1 does that make it down or upstream?
M3Armand
03-12-2013 05:53 PM
marwaanb
11-02-2010 01:03 PM
tkrick
04-30-2009 12:12 AM
ObnoxiousDrunk
03-02-2009 12:49 PM
WolfsEmbrace4681
04-25-2008 03:30 PM
