A few little engine problems....Codes
Old 06-29-2010, 07:57 PM
turbo kraut's Avatar
Tech Guru
Originally Posted by Baby Kito
Okay well here is what they mean
p1128- Long Term Fuel Trim mult.,Bank1 System too Lean
p1114- Bank1-Sensor2 Internal Resistant too High
p1602- Power Supply (B+) Terminal 30 Low Voltage
p0300- Random/Multiple Cylinder Misfire Detected
p0301- Cyl.1 Misfire Detected
p0304- Cyl.4 Misfire Detected
Now this is only saying cylinder 1 and cylinder 4. Does that mean I can just replace two single coil packs? Btw thanks turbo kraut. so far your my only help ha!
I found these two links. Which is better, the "R" or the "E"?
http://www.ecstuning.com/Audi-B5_A4-...tion/ES252896/
http://www.ecstuning.com/Audi-B5_A4-...tion/ES518032/
i think the r's are the new coils that the dealer is selling, and giving us newer b5's per the recall
i can't be positive, but i was having a lean issue, changed my alternator and it went away, reason i bring it up, is one of your codes is low voltage issue, i never had that, but it might be related to the lean
i would pm mike hood your codes, and pick his brain
Old 06-29-2010, 10:05 PM
Baby Kito's Avatar
Well I got my alternator checked and it was in perfect condition and the voltage was good so idk about that. But yeah ill PM him, but what's his name on here exactly? Sorry I'm not good at remembering peoples names on here.
Old 06-30-2010, 07:43 AM
Tech Guru
i wasn't saying it was your alternator, i was saying something to do with power might be though
his user name is
Mike-2ptzero
Old 06-30-2010, 08:46 AM
Baby Kito's Avatar
Oh alright. I'll try to look around at that and see what might be low. And thanks for the name!
Old 06-30-2010, 08:49 AM
CCA4's Avatar
try swapping the coils from 1 and 3 to 2 and 4, respectively. If the misfires follow the packs, you know they're junk. Did you call the dealer and ask about the coilpack recall?
Old 06-30-2010, 09:04 AM
Baby Kito's Avatar
I read about switching the coils around and seeing if it continued but haven't tried it yet. I haven't called yet cause I can't find any recall for my year on them, but I'm thinking of just going their a arguing until I do.
Old 07-10-2010, 10:07 PM
Baby Kito's Avatar
Switched coils but once I did the car was like undrivable so now Im down to whether its my coils, my injectors being clogged orrrrr my electrical harness that connect to all my coils. Oh and now 1,2, and 4 are misfiring but are all random but usually occur between 3-4 rpm. Clues?
  #18
Old 07-11-2010, 03:38 PM
Baby Kito's Avatar
Heres a video to show everyone why I wanna cry everyday.
http://www.youtube.com/watch?v=0Xi1YANq-p0
  #19
Old 07-11-2010, 05:31 PM
audi guru's Avatar
well this just happened to my 2.8. like exactly. and it was the coil pack. i think that is a good place to start... maybe you should check your plug wires and be sure they are all looking alright. when my coil pack screwed up it messed up a plug wire too.
  #20
Old 07-11-2010, 10:48 PM
Baby Kito's Avatar
Yeah we were looking into the coils but supposivley the ATW engine code ones are the best that Audi made for the B5 but then again it could be. Where did you get your wire harness from?
Quick Reply: A few little engine problems....Codes
