F**K.....Help me
RE: F**K.....Help me
you replace the coil pack and usualy check engine light comes off after you drive it , the check engine light should stop flashing it only flashes when its missfireing hard and the car engine shakes a bit u can tell so change the coil pack and start it check engine light stops flashing and drive it for a bit and it clears or if you have check engine light scanner then use it
well i would switch that coil pack, with another cylender if the connections are ok their, all compatible. and use check engine light scanner and it wont say cycle 2 it shell say the one were you replaced cycle 2
#20
Coils on PRE 2000 1.8Tcars almost "NEVER" go bad. The problem is gonna be your ICM (ignition control module) on top of the airbox. You can get a new one at www.ecstuning.com Its very common to get a cylinder 2 missfire when one of these go bad also.
