Euro Instrument Cluster
Old 07-26-2010, 06:09 PM
awag.13's Avatar
Originally Posted by onepoint8tee
why why why?!
haha im hoping that the U.S. will just switch to the more logical system of measuring things. and thanks fellows ill try to find one from Canada
Old 07-26-2010, 09:00 PM
vgo's Avatar
vgo
vgo is offline
Originally Posted by aledelic42
I've wanted to do this swap also. not sure if a km/h cluster would be a direct swap with the connectors but the easiest/cheapest way to get one would probably be from someone in canada. I've seen some non oem km/h gauges on ebay too. if you do this, post a thread about it!
in response...
You have bought and imported Audi vehicle into your country. In most cases the instrument cluster that is in the car either is manufactured in imperial or metric charts.
In most cases in order to convert the cluster to your country zone, you require to buy another instrument cluster from your country zone, then you need to program to match original mileage and other modules in the car so the cluster can work with other components. Some clusters come with dual chart that have both MPH and KPH charts printed on the face gauge. Usually the zone chart that you are in are printed in smaller numbers under the main chart zone that you imported car from. You can't just replace gauge face, because the speed chart are not printed identical to each other. By doing the replacement you will longer able to identify the correct speed you are driving.
We have solution for you , we can now convert your existing instrument cluster to match your country zone chart.
We can convert your instrument cluster from:
•MPH to KPH
•KPH to MPH
•Print dual speed charts
more at....
http://www.pixelfix.info/index.php?m...x&cPath=65_140
Old 07-26-2010, 09:13 PM
MartinCieslak1's Avatar
km/h FTW !!
Old 07-27-2010, 03:21 PM
Dallas09's Avatar
Ive wanted the euro cluster gauge face for the fuel. That unleaded fuel only part on the american one kind of irritates me.
Old 08-11-2010, 02:21 AM
dave0120's Avatar
not to jack the thread or anything, but i was wondering if any of you guys know if a gauge cluster from an 01 s4 would be plug and play in my 99.5 2.8, and work correctly? i searched... and this thread seemed like the best place to get an answer from knowledgeable members...
awag.13
07-25-2010 05:47 PM
igorek_k
05-02-2010 07:23 PM
asutherland
01-22-2010 09:58 AM
JETSPEED333
03-09-2007 04:42 PM
jstehle
03-07-2007 10:25 PM
Quick Reply: Euro Instrument Cluster
