Estimate cost to do a auto to manual transmission swap?
Can someone give me an estimate on how much it would cost to swap my Auto/Tip tranny with a manual? also a list of parts i would need would be nice, I could do all the work myself, my A4 already has 152,000 miles.
And unless you have an upsized turbo, the S4 trans isn't worth it - the gear ratios are optimized for the torque curve of the S4's 2.7L twin-turbo V6, which is quite a bit beefier than that of a 1.8T.
Rough estimate it can be done for 2k or less (dependent on if you have a local yard to source parts from etc.) It's fairly straight forward and you will learn a lot about the car by doing so. My advice would be to shop around for parts (clutch is the most expensive thing if going aftermarket) and see if it's worth it to you. If you plan to do it lmk and I'll answer any questions you may have.
