error code p0411
This is what Ross-Tech says:
Possible Causes
* Fuel Pump Relay (J17) faulty
* Hoses/Pipes to/between Components faulty/clogged
* Secondary Air Injection Pump (V101) faulty
* Secondary Air Injection Pump Relay (J299) faulty
* Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
* Check Fuel Pump Relay (J17)
* Check Hoses/Pipes to/between Components
o Check Secondary Air Injection Hoses/Pipes for Carbonization
* Check Secondary Air Injection Pump (V101)
* Check Secondary Air Injection Pump Relay (J299)
* Check Secondary Air Injection Solenoid Valve (N112)
Start by checking the vacuum lines, 4 for 1.8T engine, and if all the lines are ok then move on the what Ross-Tech says.
Possible Causes
Possible Solutions
