EPC Light on help?!
Anways already got a new ECT sensor and replaced that and it was working fine for a while then it started shutting down again. We'll see if its still doing the same thing with a new MAF.
Gotcha, well I started it and it ran for a while and then I hit one of the wires around the intake area and then it shut off.
Well, pulled the codes and here they are.
Power supply relay for ECU P1517
Check DTC Memory for Inustrument Cluster P1654
Brake boost vacuum system mechanical malfunction P1479
powertrain data bus missing message from TCU P1626
Power supply terminal 30 voltage too low P1602
Mass airflow meter signal too low P0102
Load signal error message from ECU P1857
Cleared all these codes but now i'm kinda at a loss.
mannyg_87
02-23-2015 03:08 PM
crazybk187
08-05-2013 04:29 PM
Pbcrazy
09-07-2012 04:25 PM
