Engine Noise? Video
Old 10-30-2012, 03:23 PM
Sheasta's Avatar
Default Engine Noise? Video
Sounds like ticking? You can kind of hear it in the video I made. Any ideas what that might be? Sounds like its coming from the rear of the engine like cylinder 3 or 4 area but its hard to tell. Its at operating temperature after a 15 minute drive. Yeah the valve cover is very dirty..... and thats after using degreaser and rags on it...
Old 10-30-2012, 11:45 PM
Sheasta's Avatar
Bump----- ideas? Suggestions?
Old 10-31-2012, 12:14 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Ticking from the back of the head is most often tied to the cam chain tensioner.
Old 10-31-2012, 03:21 AM
Sheasta's Avatar
Ii was thinking that but the noise isnt as consistent as the cct was in the videos i saw.
Old 10-31-2012, 07:36 PM
Sheasta's Avatar
Bump. Just looking for more input.
Old 11-02-2012, 11:42 AM
Sheasta's Avatar
Possible second opinion?
Old 11-02-2012, 02:05 PM
CCA4's Avatar
I vote CCT as well. What do you mean by "isn't as consistent?" Sounds like the frequency of the ticking goes up and down with engine RPM just as it should.
Old 11-02-2012, 02:21 PM
Sheasta's Avatar
Maybe I should have worded it differently. I mean in other cct videos symtpoms ive seen its louder and always there. It probably is the cct im not disagreeing as much as if it isnt cct then its....?
Old 11-02-2012, 04:53 PM
zandrew's Avatar
I have what I am guessing is a cct issue as well. I hate it because my cars sounds like a diesel and if I wanted it to sound like that I would buy a diesel instead. Can it be fixed and if so what will I need? It literally sounds identical to a Toyota 4AGE that the valves need reshimmed (basically having the lash set).
Old 11-03-2012, 08:34 AM
Sheasta's Avatar
How tough is this job? Dont you just take off the valve cover take out the old tensioner and put in the new one and pull the pin? Like the timing belt tensioner? Or is it different?
Quick Reply: Engine Noise? Video
