Electric radiator fan replacement?
Old 08-02-2012 | 03:59 PM
snatchman's Avatar
Default Electric radiator fan replacement?
I have an 2000 A4. 1.8t that needs the electric radiator fan replaced. I have looked for DIY on this but couldn't find any. Would appreciate any help.
Old 08-02-2012 | 04:09 PM
jonbonesjones's Avatar
Moderator
look at a timing belt diy to get the front of the car into service position. the rad fan shouldn't take much more to get out.
IanWPB's Avatar
It should be very simple.. Find any of the DIY's for removing the front bumper and loosening the lock carrier. From there, it should just be a couple bolts supporting the fan and an electrical connector IIRC.
Old 08-03-2012 | 11:51 AM
bshusted's Avatar
I think you can do this without putting the car into "service position". There is a single screw in the top. At the bottom there is a latch that you pull back on. Then rotate the whole thing to clockwise when viewed from the front of the car. You can then pull it out of the lock carrier.
The most difficult part of this is going to be fishing the wires out of the bundle on the carrier.
Old 08-03-2012 | 05:51 PM
IanWPB's Avatar
I think it's the big red connector for the a/c fan.
GB1
05-25-2014 05:19 PM
bevanet
06-25-2011 11:33 AM
mbonadio
04-05-2010 06:24 PM
767Jockey
07-01-2007 01:16 PM
david9999
06-07-2006 01:33 AM
