Ecu tuning diy?
Ecu tuning diy?
hi:
Sorry, any here has any idea how to flash a ECU by self?
I have an 2001 A4 B5 1,8T quattro with manual trans. I really want to upgraded it to a higher performance. I am wondering is there anyway I can do this, like what APR does, all by my self? If so , would you please tell me what do I need and basic steps of how to do the ECU tuning/flash? Thanks a lot.
Nick
Nick
If you have to ask about tuning yourself, then I wouldn't recommend it. Using home tuning programs, so I've seen, are left to guys who are very knowledgeable about their car and have a very good understanding of the systems, usually mechanics of some sorts or can break down their whole car with a pair of vice grips and a Flathead lol. What you can do is the diode mod, but I would only recommend doing something like that if you are planning on going BT in the very near future and don't want to spend the money on a chip that you are only going to use for a very short period of time. Plus, the diode mod isn't going to be able to give you the numbers that a professional tuning company could. I think you can only safely push 16-17 pounds (spike). And as with all tuning, you are going to need an upgraded diverter valve and boost gauge. Also, if you plan on doing the diode mod, you will need to get a MBC or an EBC. I recommend just getting the chip. You certainly won't be sorry you spend the money cause its the most bang for your buck you will get for this car. Hope this helps.
You own a Audi not a honda. lol
There is no short cut to tuning your stock ecu on your own. Just buy a chip and have a tuner flash it. If you check around you might be able to find someone selling a ECU that is already chipped.
It depends on what company you go through. There are some tuners that will actually put a physical chip and there are others that will do a flash on your existing hardware...it all just depends on which company you go though but either way is going to be fine.
ECS Tuning
S4
02-22-2013 03:54 PM
Andrew/AWE
09-19-2012 12:20 PM
Andrew/AWE
09-18-2012 07:10 PM
Joe/AWE
02-06-2012 12:19 PM
Aliel
05-10-2006 03:01 PM
