ECU going bad?
#22
Got the hood open. A quick disconnect/ reconnect of the ECU didn't fix the problem. I pulled the ABS fuse and tried to scan. Still no luck. Thanks for that tip, though. It was worth a shot.
So, now on to investigate this "coolant migration" theory.
#23
I highly doubt it's coolant migration. I checked the connector under the coolant reservoir and it was clean as a whistle, dry, with no crusty anything.
After trying to start, the throttle body is making some pretty loud noise and stuttering all over the place. I don't think I've ever seen or heard it like this before.
Edit: I did have the battery disconnected momentarily while fiddling wih the ECU. It may just be doing an alignment.
#24
After trying to start, the throttle body is making some pretty loud noise and buttering all over the place. I don't think I've ever seen or heard it like this before.
#26
I've given up for the day... Does anyone have a known-good spare AEB ECU laying around they wouldn't mind letting me borrow to see if that's the problem? I really don't want to buy one and find out that's not the issue.
Also, I have an APR tune, but it's from the PO. Does anyone know if APR will re-flash a new ECU for me for free?
#28
I would get out a volt meter , check for power & grounds that supply the ECM. You might have a power supply issue I.E. a bad power feed relay. Get hold of a wiring diagram & start doing homework!
#30
Can anyone else weigh in on this interchangeability issue? Some searching here (and google) has led to some mixed answers. Some people say they've done it, and as long as the part numbers match, there won't be an issue. Others have said it didn't work...
I really don't want to drop a bill and find out it won't work...
Pat, I know what you're going to say. Trust me, it's on the list.
