:: ECS Tuning :: B5 A4 1.8T RA4 Clutch Conversion Kits
Why not replace your worn stock clutch with something special?
The ECS RA4 lightweight flywheel weighs in at a trim 12 pounds, compared to the hefty 26 pound flywheel shipped from the factory, and increases diameter from 228 to 240mm. Off the line, that's like lugging 250 fewer pounds of vehicle weight all while improving power transfer.
Bolt these beauties on to your 1.8T with no additional modifications. The kit includes original equipment hardware and clutch alignment tool, so things slide together easily.
Improved low-end throttle response. Smooth operation. Less lost power off the line. Stronger and tougher than the original.
We have three great clutch conversion kits built around our ECS-engineered lightweight RA4 flywheel, Stage 1, Stage 2, and Stage 3 each offering different levels of performance.
Stage 1 Features:
- ECS RA4 Clutch conversion flywheel
- ECS clutch alignment tool
- S4 pressure plate/disc - Clamping force strong enough to handle the B5 S4's 251 horsepower
- Installation hardware
- Pilot Bearing
- Clutch Release Bearing
Stage 2 Features:
- RS4 pressure plate/disc - Clamping force strong enough to handle 375+ horsepower
- Pilot bearing
Stage 3 Features:
- Clutch Masters FX300 pressure plate/steel-backed Kevlar segmented disc - 110% increase over stock S4 clamping force.
- Pilot bearing
If performance is job one on your to-do list, ECS Tuning flywheel kits deliver.
So Clutch
Click HERE to order or for more information
Fits:
Audi B5 A4 1.8T (1996-2001)
Let me know if you have any questions.
Jason
ECS Tuning
03-06-2015 12:20 PM
ECS Tuning
05-14-2014 11:10 AM
ECS Tuning
02-18-2014 01:28 PM
ECS Tuning
07-23-2013 03:59 PM
