E-brake freezing
E-brake freezing
When it is about 25 degrees F or lower my brakes freeze. When I engage my e-brake ( not tight at all maybe two clicks ) the brakes will freeze within an hour. The e-brake goes down fine from inside the car and when I wiggle it up and down it seems smooth and normal. When I try to take off the brakes are still engaged, takes about an hour to relise even if the car is warm. I had my e-brake cable loosened and had it looked at and was told it was fine. So I'm starting to think this is a caliper problem? Anyone else have this problem?
I just had the same problem.
Basically you probably have air in the abs pump that is freezing. You need to hook vag-com to bleed it.
Put the car in your garage or something so that you can defrost the air bubble and then youll need to do the bleed.
http://www.ross-tech.com/vag-com/cars/absbleeding.html
Then you'll have to do a caliper bleed. My left back caliper is the one that is stuck so thats what i'll have to bleed. I'm just waiting for my cable to come.
Er, what? It'd have to be awfully cold for that. Water in a mixture (as opposed to a solution), perhaps, but air freezing? Hmm.
well whats wrong with anti seize my father is an ase cert tech and hes been useing it for the better part of 20 years and has never had a problem or a comeback i guess thats just my personal preference and i know what works from my experiance
