dv relocation kit for a4??
i was bored on my lunch break so i did a seach for dv relocation and every thing that it came back with was for the TT's does anyone make a kit for the A4 and would it have the same effect??
search i did https://www.audiforums.com/searchpro...mitbutton=+OK+
RE: dv relocation kit for a4??
The effects will be the same. You can get a pipe with a flange welded on from ebayand then just cut the TB hose and insert the pipe inside and then clamp the TB hose back on the pipe and then run a new hose across the engine bay to the intake.
you want the metal one (doesnt matter what) so you can insert it in the TB hose. You cut the hose in 2 and then make 1/2 circles for the flange and then insert the pipe in the hose and clamp it down. Then route like stated above. You can get a flange for a turboxs on ebay you can use
ha i finally found one they are called bov adapter pipes not 't' pipes
http://cgi.ebay.com/ebaymotors/1-3-8...spagenameZWDVW
and don't forget the blank plug
http://cgi.ebay.com/ebaymotors/ws/eB...23892&rd=1
total for both 35.00 shipped ill probaly spend another 20 on hose or misc supplies total for it all 55.00 roughly
Red_sapphire89
07-06-2008 10:48 AM
