Durability of 1.8T
RE: Durability of 1.8T
"taken care of in regards to letting it warmup and cooled down, failure to do so can lead to sludge and varnish which *will* destroy it prematurely. This becomes even more important with a chip and BT. "
Wow: warmup needed (I thought this is a thing of the past)? Need guidance: How long? (assuming that water or oil temp has reached a certain level. How? (Assume keeping the load (gas pedal) and RPM down (how low)?
Even more: cool down? How? Let car idle for a while before shutting off (that typicall INCREASES the temp stored in the engine)? Ease of the throttle on the last mile before shutting the car down?
Volker
Volker
ORIGINAL: vtraudt
What is a BAT?
I assume OCI is Oil Change Interval?
Volker
What is a BAT?
Volker
OCI is a new one on me... usually LOF (lubrication, oil & filter) is the acronym.
The turbo is usually the only thing you have to worry about with higher mileage. Other issues are timing belt services and synthetic oil changes to prevent sludge.
Nice choice, good luck!
ORIGINAL: vtraudt
Volker
Volker
Your engine temp should not increase while idling (could mean you need a new thermostat- not a big deal to fix) and the oil temp will go down.
my 1.8T has a leaking valve stem guide that, combined with a clogged catylitic converter caused the turbo to over heat and damaged the spool. the turbo sounded as if the spool was making contact with the outer shell when it tried to spool up. this happened at 108,000 but i think it was caused by the use of low grade gas and standard oil by the previous owner. does anyone have any advice other than a new cylinder head and a new turbo? also, in reguards to the turbo needing to cool down... the audi S4 2.7t will continue to run the cooling fan after the car is turned off and key is removed. this is true of several other turbo cars so just to be safe i would let it keep circulating for a few minutes after a hard run. if you are really concerned about your turbo over heating though you should consider a FMIC. its the most efficent way to keep the turbo cooler.
#18
Additionally, the coolant fan runs with the engine off to keep air moving across the engine bay when it's hot under there. It's not sufficient enough to cool a red hot turbo after a hard run. That's what turbo timers and electric water pumps are for.
#20
ORIGINAL: Tweaked
It only takes a timer or relay (no cost). Are electric pumps available as aftermarket?
Has someone rigged it that way?
Volker
