Dumb Question, Spam on!
Old 11-24-2009 | 07:33 PM
audi_n00b's Avatar
Default Dumb Question, Spam on!
I have a vvme HID kit and one of the bulb's went out. Can I just replace the bulb or do I need a new bulb AND ballast? Thanks...
Old 11-24-2009 | 07:36 PM
auditech79's Avatar
The bulbs have the same sockets, put the good known bulb in the socket that isn't working and see if it works. If the other bulb lights then you just need a bulb, you can also try the bulb in the other socket to see if it lights on the other side which would tell you if its a bad ballast. Knowing the chinese, it can be either of them.
Old 11-24-2009 | 08:11 PM
shortyxc's Avatar
You should just be able to replace the bulb. does the ballast make noise (high pitch humming sound) when you turn your lights on? If it does then the ballast is fine and the bulb actually is dead. If not then it is the ballast that needs to be replaced
Old 11-24-2009 | 10:41 PM
ImTheDevil's Avatar
I bought a pair of replacement bulbs on eBay from a seller in NYC for $22 shipped. Buy a pair and replace both so the bulb colors match and save your existing good bulb for a backup.
Old 11-25-2009 | 03:56 PM
shortyxc's Avatar
^ good thinking. I have HIDs my fogs, so thats where my spares will come from lol
Old 11-25-2009 | 04:29 PM
kriptonik's Avatar
Do what auditech79 said. Make sure it's not the ballast.
Best of luck!
pyrobionic
01-05-2014 09:15 PM
Tadyswoows
08-18-2006 08:22 PM
Trey25
06-13-2006 04:22 AM
lidonnit
07-04-2005 12:28 AM
Quick Reply: Dumb Question, Spam on!
