Drive Train buck?
Drive Train buck?
So heres the problem, when i am driving in the snow, every once in a while my car will quite literally buck. it nearly feels like having the clutch being dropped in on a bad shift. the whole car feels like it "stops" and there is quite a loud clunk noise from the under carriage. any help on this problem would be awesome, but after talking to a few other owners it doesnt seem like a very common issue.
Might you know if it is similar to what a ball and spring MBC might cause? just brain-storming. I have felt that clunk with those before. If it is, there may be suggestions for that floating around. bad n75 or chip tuning? Use a different mbc?
I have a 2.8l 30v the only real modification that i have personally done to the car is to get a speedtuning chip. all the other listed upgrades that are on the car were done by the previous owner.
And just to make sure, a MBC is a manual boost controller? which unfortunately does not apply to my situation.
does this happen regularly? can you replicate it? or was it a one time thing. it could have been a chunk of ice in your wheel well falling onto the tire and getting smashed between the fender and the tire or something similar.
the only drive aid that i know i have is ABS.
[QUOTE=hiwords;1036269]that's weird, i've never heard of anything like that. i'd check the tranny and engine mounts first.
is there an easy way to check those to see if they are worn or failing?
you just have to get under the car and look at them. get a little pry bar and see if you can get the trans to move easily, it shouldnt. if any are cracked, which a few probably are if they have 100+k miles on them, replacing them might help. i replaced all of mine with 034 street density mounts and it was a huge difference.
