Drive Shaft Carrier Bearing...Can I replace it??
So, after a lot of searching and reading on this forum and others, I'm 99% sure that the drive shaft carrier bearing on my '99.5 1.8T Quattro is shot. Does anyone know if I can replace just the bearing myself? If so, is there a write-up anywhere that could help me with this job? I used the write-up I found on here to replace my wheel bearing and was hoping I could do the same with this. Any help I could get would be much appreciated!
Thanks.
Thanks.
Did you have to use the SST to remove the drive shaft? How did you get the bearing off and back on? I'm willing to have the pain in the A$$ rather than a bigger pain in my wallet, especially this time of year. If you could just kinda walk me through the key points of doing it I'm comfortable enough with cars that I could probably fumble my way through it, and maybe even make a DIY instructions along the way. '
Thanks!
Thanks!
