Door wont open
had a similier problem but my door opened after i dropped a shoulder from the inside i spent 2 weeks with bp blaster and it got to a somewat better point it is still hard to open and have to slam it shut...my next step is replacing the latch and cutting my losses i suggest you do the same because if the door does come open theres a chance that it wont close or the latch will be bent sooo thats the recommendation i would give and do it all at once....goodluck and let me know your progress
Everything in the world is good now, problem solved it was the lock after playing with it for a little bit it finally popped all the way up. Put some more lube in it works like a champ now. Thanks for all the help
#18
Well what I did to get mine open is I put some lube in the lock hole, locked and unlocked it a couple times to get the lube down in there, but had now luck till a couple days later. I was trying it again and when I would unlock it I would try to open it as its unlocking, I think I might have been pulling up on the lock also, but after a couple tries it popped up all the way. Than I put some more lube inside it and now its works like a champ. Hope that helps
