door locks and sunroof issues
today my door locks decided not to function anymore with the key remote and from inside the car using the door unlock button. My gas tank however remains always unlock which is a good and bad thing. I have to lock and unlock the doors manually and individually, my alarm how ever still works. Is it the vacuum pump that's not functioning properly or is the the convenience control module or both? Also my sunroof doesn't like to close properly, most of the time when i try to close it it gets to about an inch of closing then it would just open again. I checked the rails for any debris or anything that would prevent it form closing but there is nothing that would cause such a problem. Is it the motor that's shot or is it something else. Thanks.
I'm stumped on the door locks...do they open and close when you use the convience feature with the key?
As for the sunroof, that sounds like the switch is shot. I understand that to be a common problem on our cars.
don't hear the pump on the door locks period, no sound anymore that i'm used to hearing wen i use the remote key to lock the door. i have to use the keyhole to unlock the driverside door and it only open the driver side door and lock the driver side door. There is no pump sound, i went to the trunk and removed the right side lining and located the pump and there is no sound from there. But is there more to it? and not just the pump?
brettmichaelsmith
04-07-2014 11:00 PM
markymarc
03-11-2012 01:02 PM
babyvan
05-28-2009 03:35 AM
quattromond
08-11-2006 01:28 PM
