Door lock problem!
The vacuum for the 2001.5 (not sure if it's the same for older ones) is located inside the right side panel in the trunk.
You would need to unscrew the plastic panels on the back part of the trunk to access the vacuum.
You could go to the dealer to replace it or DIY.
http://www.audiworld.com/tech/elec149.shtml
