Doing clutch job, want to add oil pump?
Old 02-11-2013 | 05:54 PM
jonbonesjones's Avatar
Moderator
  #22
Old 02-11-2013 | 06:11 PM
Pbcrazy's Avatar
Originally Posted by jonbonesjones
Makes somewhat sense but you would still have to drop the sub frame, and I don't have an extra set of mounts not do I want to spend tons of money to get them
  #23
Old 02-11-2013 | 06:40 PM
Mike-2ptzero's Avatar
I don''t know many A4 owners that just have an extra motor mount brackets laying around and they aren't cheap brand new.
Taking the motor out looks like less work then playing Red Neck mechanic. lol
  #24
Old 02-11-2013 | 09:29 PM
Pbcrazy's Avatar
The other problem is, isn't the subframe under pressure? So how do I get it back in place?
  #25
Old 02-11-2013 | 09:44 PM
Moderator
its not under pressure. put the bolt in and impact it up. Its just heavy
  #26
Old 02-14-2013 | 04:00 PM
Pbcrazy's Avatar
Then why is it so time consuming/hard to remove??
  #27
Old 02-14-2013 | 04:25 PM
Moderator
Who told you that? I can get it off in under 30 min easily
  #28
Old 02-14-2013 | 08:10 PM
Pbcrazy's Avatar
...the what's so time consuming about removing the oil pan? I thought once you drop the subframe you just undo the bolts and it comes right off? Am I missing something?
  #29
Old 02-14-2013 | 09:39 PM
Moderator
i think its just the face you have to take off the sub frame is just a bugger pain in the ***.The 2.8 oil pan is right theres just hit the bolts with a 10mm drill and it takes no time at all.
MetalMan
07-19-2012 09:15 PM
Sardor
09-07-2010 06:02 PM
SupraSkylineSTI
03-11-2009 10:19 PM
Quick Reply: Doing clutch job, want to add oil pump?
