Doing a Boost Leak Test, am I supposed to plug this?
This has probably been asked a few times. I have searched but have been unsuccessful.
I am following this write up:
http://www.a4mods.com/index.php?page...boostleak.html
I've already fabricated a plug for the turbo inlet pipe (why isn't it called a hose?), a plug for the opening in the turbo inlet pipe when you remove the pressure regulator valve.
My question is when you remove the pressure regulator valve are you supposed to plug the other end that it connected to also(PCV return)?
I also found oil in the pressure regulator valve and some oil residue on the hose that connects to the throttle body a while back when I cleaned the TB. Should I be concerned?
The oil you saw is common, and one of the downsides to the PCV system. Recirculating the pressurized air from the valve cover/crank case back into the intake allows the oil vapor, condensation, and other gunk to go back into the intake tract, through the turbo, boost hoses, intercooler, and ultimately the throttle body. A good solution to this problem is a catch can, if you'd like more info on that PM me and I can fill ya in.
As for the other end of the pancake valve, you don't need to plug it. Just plug the hole in the tip where you pulled it out of.
