Does the ATP manifold fit the wastegate without a spacer?
I called their customer support and was told that the manifold pushes out further than the stock mani and that the 38mm wastegate can be mounted on top without a spacer, even thou this is the B5 forum I'll go ahead and say this is for a 1997 audi A4 1.8t Engine Code AEB, Quattro. To me it looks like a super close fit, I've seen other 20v engines on the vortex using spacers and such. Hoping that the longitudinal setup tucks it. Let me know.
now do I want it to just space the wastegate, of do I want it to space the wastegate and also spin it 90 degrees? I'm going to have to weld the piece myself and I guess take it to go get ceramic coated so I want it to be as perfect as possible the first time I make it. Also do I use 38mm Flanges? And how many degrees approx should the bend be?
No I dont but you can order it directly from ATP
http://www.atpturbo.com/mm5/merchant...Category_Code=
RaivisGertners
11-11-2018 11:15 AM
